As i have been looking at my project waiting to buy more epoxy to put my floor in, i have noticed more and more places where the fiberglass has an air bubble or is raised up from the wood in the corners and at the 90 deg angles. how bad are the air bubbles underneath the fibergalss. my solution to the tops of the stringers was to grind it off where the seperation has occured. i am using 8oz woven fiberglass. is there a lighter weight fiberglass that can be used for 90 deg angles and not bow out. my current plan is to re-epoxy the whole tops of the stringers before putting on the floor. for the corners i plan on putting a mixture of thinkened epoxy with some milled fibers to connect these areas.
