storedaddy
Thread starter- Joined
- Oct 26, 2009
- 18
johnson 1979 15hp, when motor is started air bubble come up from the the lower unit in the area of the water pick up and the connection to the upper housing is this a bad seal? the fluid is good not milky. 2--> what is under the small freeze plugs on the carb I am having a problem getting the motor to idle I pulled the carb apart and it was spotless I removed the large freeze plug and it was clean also blew air through all of the passages and it seemed ok so I did not take the other smaller freeze plugs out. could this be the cause of the no idle? start easy throttles up good. should I just try to decarb? get new fuel?
