AGM battery charging question
Sonar33
I just bought a Cabela's AGM battery to run as a cranking battery and also power my accessories (depth finder, radio, bilge, lights). I'm confused as to how often I'm suppose to recharge it. I've done some research online and seen advice to charge immediately after discharging. Does that mean every time I use it or wait until it gets to 50-60%? I've used it once and it's at 85%, but I'm not sure if I should charge or not? Any help would be much appreciated since these batteries aren't cheap and I'd really like to maximize its life.
Thanks!
BoatNoobie
Re: AGM battery charging question
to maximize battery life, always recharge it full after using it.
Silvertip
Honorary Supreme Mariner
You said you are using it as a cranking battery. That says electric start on the engine and that also means (generally) that the engine has a charging system and that also means the engine charges the battery any time the engine is running. So just like your car, you don't need to manually charge the battery. If the engine does not have a charging system then yes -- as a minimum, you need to put it on a maintainer or smart charger immediately after use regardless of its current state of charge. Back to the engine charging system -- just because the engine charges the battery, it's output determines whether or not it can keep up with the electrical demand. If you draw 10 amps with the engine off and the alternator output is only 6 amps at wide open throttle you are losing ground so charging is mandatory. But once again, there is too little information for us to go on since we don't know what engine you have, what the charge rate is, and what the total current draw is and how you use the boat.
