After washing engine, water stays in the lower engine tray
dcanelon
Hello friends, my motor is a 1997 Evinrude Vindicator 225 hp model BE225SLEUD, with less tan a 100 hours, which had been stored for 10 years, its really new, anyway, I took it out and among other things changed the w?ter pump, cleaned the 6 carburators, and washed it, and here is the problem, water will not leave the lower engine tray easily, staying there for a long while. I tried with a high pressure hose with no results, so then, is it plugged?, do I have to disassemble the lower engine tray?. Any feedback will be greatly appreciated, Douglas.
PS In other threads, I shall let you know about this outboard after more than 10 years stored.
Re: After washing engine, water stays in the lower engine tray
So if I'm understanding this, the water isn't getting in the lower cowling from anything the engine did, only when you pointed a hose at it? Honestly if it were me I'd just drill a quarter inch hole or two in each side of the lower cowl.
jrs_diesel
Most engines have drain holes in the lower pan. My 86 Johnson 9.9 does, as well as my two Johnson 6 HP's, both from the 70's. The ones on my 9.9 were clogged from gunk and from sitting for a few years. Once I cleaned them, water drains right out.
boobie
If it's been stored for 10 yrs it may have a mud dobber problem.
phillnjack2
Ensign
have a poke around and find the drain holes.
and next time have it tilted fully up when washing it !!!!!
phill
