after some advice with a evinrude 30hp outboard E30ELCCE
falcore
G'day,
new to boating so just after some advice regarding the above outboard.
apparently run 80-90 oil in the bottom? how much would one use? figured out the drain plug for that and the fill point. is there any other places use oil in these engines?
it runs well etc but just want to make sure i look after it. on the side of it says 100:1 but saw on the net somewhere its better to run a richer mixture?
have done a lot of mechanical work in the past on vehicles so can pick things up easy enough....
any help would be greatly appreciated
Andrew
flyingscott
filling the lower unit is a pretty straight forward job it is much easier with a pump you can get from your local marine store. You just have to remember to fill from the bottom screw until it comes out the top screw. Do not run 100:1 in that motor that was a bad idea that omc had run 50:1 and you will be good.
falcore
So apart from the lower leg there's no other oil to change? May sound stupid but why can't it be filled from the top? Make life a lot easier that's all.
Cheers regarding the mix, will add some more oil to the fuel before next use.
Honorary Supreme Mariner
It will not be easier to fill it from the top !!--There is no way of knowing when it is full of oil.---Fill from the bottom as all the air is pushed out.---And yes you run that motor at 50:1 gas oil mix with no guessing on that
falcore
I gotcha regarding the oil now. No chance of air pockets etc in the bottom.
50:1 is to easy :) everything else at home is as well
