Re: after changing impeller ???
Hi, Matt. You can't normally tell by eye, if the seals need replacement. The best way to tell,is with vaccum and pressure testing the lower unit after the new impeller has been installed, and you are ready to bolt it back on.<br />Most guys don't have the equipment for this, but a bicycle pump with a built-in pressure gauge,hooked-up to the vent or fill screws, can work as a makeshift pressure tester. Pump it up to 5-10PSI,and watch for a drop in pressure on the gauge. If it drops, stick the entire l/u in a garbage can filled with water,and pump it up again. Look for the bubbles. This will show you the bad seal or seals.<br />The lower unit goes on in the reverse order of how it came off,pretty much. Just be very carefull when lining everything up.<br />My advice is to get the shop manual before starting this. It will pay for itself, i promise.<br />You will most-likely spend an entire weekend,book in hand, to remove it, replace the impeller,and remount it. But less than 1 to 1.5 hours any time thereafter.
