- Mar 8, 2009
- 43,683
Didn't pull the drive last spring or fall on the Rinker, reason only put maybe 15 hours on the boat. So the current plan was to take some friends out to the far end on the lake (22 miles). Figured going that far I need to do some checking.
Pulled the drive and there was a little bit of lube in the boot, not much, would be of no concern with pressure checking later.
Then noticed a slight bit of brown in the lube located in the shift foot hole. Removed the top and back of the drive housing and found a slight leak in the O-ring gasket on the back shift foot area. Shows that a bit of rust had started but still slight.
Bought the boat new in 1994, and have been neglecting it a bit do to so little use. Has 667 hours on it and still a real good boat, have no complaints
Looked at the original boots are they still look great, moved then all over the place trying to find cracks but nothing. Guess I will use it the rest of this year and change them out this fall. At least that's the current plan
Bought new seal kit for the upper, hope it comes in soon so I can get her back together. Also bought two new water pump kits just cause
