Advice please
ClintonW
Hi All,
Firstly thank you for letting me join this awesome forum!
I have a 3.0 MerCruiser inboard and can’t seem to get the engine to crank after sitting for 4months.
Battery good as have kept it charged, no corrosion on cables to starter solenoid, starter relay clicking when turning the ignition switch.
When turning the ignition switch, there is a fan type of noise coming from the engine but does not crank. See video.
Do you think the starter solenoid could be the issue or something else?
Appreciate the advice
  • IMG_2246.mov
dubs283
Operator seat presence switch. Not referring to your lawn mower
You own a multimeter?
Grub54891
If the starter is spinning but not engaging, it's probbaly the battery. Even keeping a battery charged won't work if it's no good. Easier to remove battery and have it tested.
alldodge
I would say either at actuating arm is disconnected, or the starter is loose from the engine block
kenny nunez
If you find rust on the shaft next to the gear try cleaning it. Sometimes that will cause what you are describing.
QBhoy
Yup. Definitely your bendix isn’t throwing up. Either solenoid sticking or a compromised and lack of juice to the starter causes this.
Now the starter is off…test it with jumper leads across it on the workbench. If she’s not coming up..take it apart and have a look in there. Likely full of carbon dust and/or corrosion water ingress signs even.
tank1949
Hi All,
pull and put starter on a work bench and spin it over via jumper cable. If not, may be a bad starter. Pray that you have not hydro locked motor during offseason and the humming is due to starter Bendix being toast or ring gear toast.
