silversniper
Thread starter- Joined
- Nov 3, 2012
- 5
Hi all,
I've got a project going to restore a Johnson 4w69B (my first outboard!), which I have mounted on a dinghy and use for bass fishing on local lakes. However, although the motor runs ok, it has some starting and stopping issues that I'd appreciate some help with.
Firstly, I've discovered some issues with the mounting height of the motor. It used to cut out a lot and I think this was due to the exhaust ports being submerged - now that I've raised the motor up so these ports are above the water line these cutting out problems have reduced to very rarely. However it may be a factor in the other problem I've got - which is hard starting, and which I'm still trying to figure out the cause.
Currently the motor takes about 10-15 pulls on the starter rope to get going. Sometimes less and but not normally much more. The procedure seems to be that it only starts when the throttle is on full and the choke lever is out, but only if I've pulled the starter cord a few times beforehand while the throttle is off and/or the choke lever is in. It's not a case of just hammering on the starter cord with the choke lever out and the throttle on full until it starts, so I think I've got an issue with the fuel lines or the carb.
Once I've got it going both the high and low
-re the fuel lines. I definitely think one has got a leak because when I squeeze the primer bulb I see a fine spray of fuel near the fuel pump. Unfortunately its right down in there and I can't yet tell where. Can anyone please tell me what diameter fuel lines I need to order for replacements? And is there a better method of attaching them than the little wire spring clips?
-I've also spotted that one of the spark plug leads pulled free from its 'boot' attaching it to the lower spark plug. I've cleaned the wire and reseated it - but is it only meant to be held in there by friction? I worry that it will pull free again and I won't know.
-I expect people will tell me to clean and restore the carb, and I will do this, but I don't know the part number for the correct Carb rebuild kit for this engine. I would appreciate some help please, I'm ideally looking for the one with the new float.
-re starting procedures. I'm concerned that I'm somehow flooding the engine by starting it with the throttle fully open. I also can't figure out why I have to open and close the throttle and the choke before it will start. Is there anything I'm potentially making worse by doing it this way?
