Hello Everyone,
I am restoring a '64 Naden 16' deep and wide, pictured below (in 'before' condition). I have been keeping an eye out for a good engine to put on it. I believe the boat is rated for a 35 horse, so 18 hp is underpowered, but I'm really not fussed about speed. This would be used only for local fishing trips.
I am going to be taking look at what I am told is a pair of '64 Evinrude 18hp engines. The information give by the seller on them is taken directly from the ad.
"2 x 18 hp - 1964 Evinrude twins long shafts - Both for $375. I have parts to make one short shaft if needed. They both run great and have low hours. One is electric and pull start the other just pull start. I changed points, condensors and coils. One does leak in bottom end so is being sold as parts or fix up and the other is good. They are in very nice 64 vintage shape!"
I contacted the seller and got this information:
"I purchased them from someone in eagle. Original owner passed away 20 years ago and they sat in garage for many years. Came off of a 1964 star craft. I still have the boat. I installed a older 85hp this year in the boat. So selling the twins. They run good but one if the motors leaks water in to gear box and will need fixing. Could use that one as parts as it does run good. I redid the ignition/coils when I bought the boat 4 years ago."
I asked if the engines were both run on the original boat, and got this answer:
"Yes they ran in sync on the back of the boat. The one with electric start was probably his trolling motor so that one many have more hrs. on it then the other. The electric start is the one that is leaking."
So that is the story - seems a little unusual, but such is life. The price being asked is $375 for both.
So I have a few questions:
- what should I look for when I go out to see these engines - any particular tests I should do?
- how easy is it to get parts for these motors?
- any general comments you have on these engines?
