advice johnson 1965 cooling
bean1969
please can someone clarrify for me if my rd 27 will cool properly with a later model evinrude 40hp bottom section that has different pump configuration it fits okay but top end is not cooling.the return water tube on rd27 goes back into the pump but is bypassed on later model thou there is a spout for it but i do not think it actually lets water into pump is this why engine is not cooling correctly.could i just bend rd 27 return so it bypasses pump on later model bottom leg to let water escape
Honorary Supreme Mariner
You need to order the correct parts in order to make this work !
F_R
The outlet water does not "escape". It is returned to the inlet side of the pump for recirculation. On earlier models that was done at the pump itself, but later on it was done in the bottom of the case, between the inlet screen and pump inlet. Either way, the result is the same, the outlet tube connects to the pump inlet for recirculation when the thermostat is closed. You can use the later gearcase on the earlier motors by replacing the outlet tube with one that goes clear down to the grommet in the case. Just buy the proper tube for the gearcase in use.
bean1969
thanks f r i will take the correct return tube off later engine and bypass pump spout and fit to lower grommet in lower case.the only reason i was going to bend rd27 return tube was so that it did not locate direct into later model pump because even thou there is a entry for it ,it is blocked off so water cant enter pump and so causing dead end so water could not flow round engine that was my thinking.so am i led to believe then that the engine relies on the return water being recirculated at all times or just when stat is closed thanks
F_R
When the thermostat is closed, most of the water returns to the pump for recirculation, except for some that is discharged to cool the exhaust. When the 'stat is open, most of the water is discharged, but some may still return to the pump. That is not a either-or situation. The thermostat is constantly sampling the water and opening or closing as necessary to maintain proper temperature. The point in all of this is that there cannot be any way for AIR to get into the pump intake.
bean1969
thanks again f r for the information i not having the return in correct location im getting air in pump and she is not cooling .i guess i doubted the return flow was that important because when i connected a hose pipe to opposite tube ie inlet she cooled ok and there wasnt alot of water coming out of return that i thought would make much difference but it obviously does thanks again for explaining the importance of return flow
