To adjust the idle on this motor do you adjust the carburetors or the timing? Are there high/low speed adjustments on these 2 carburetors? The motor dies every time you try to put it in gear. If you idle it up the gears rake and make noise. So far we have a new plugs,new power pack,new solenoid, and the carbs have been cleaned, compression good. Three mechanics can't get this motor running right, is the motor a lemon or do I need more new parts?
