Matthew A.
Thread starter- Joined
- Jan 24, 2006
- 232
Hi everyone,
Wow! been awhile since I've visited this forum. Greetings all.
1986/88 Force 85 hp.
I am having a bit of difficulty in adjusting my motors air/fuel mix. It would seem that when I attempt to find the point where the motor is running too rich before setting the mixture halfway between too rich and too lean, the air/fuel screws on all three carbs can be backed out until no longer threaded [or damn close] before the motor shows signs [running rough/low idle] it's about to die. The idle speed is set to 650 to 750 rpms at 0 degrees advance.
All carbs adjusted 1/16 to 1/8 turns each while engine running
Lean condition reached @ or near 1/4 turns out from seated [all carbs]
Choke butterfly's fully open on all three carbs.
Air/fuel mix screws initially set @ 1 1/2 turns from seated
Warm engine
Fresh fuel/oil
New plugs
Sea level @ 75 degress F. and 30 percent humid.
25 hours on full rebuild
Throttle butterfly's in sync for all carbs.
Any idea's what's goin on [meaning...how come air/fuel screws can be backed out so far without much affect on run condition of engine.]
Warm engine
Fresh fuel/oil
New plugs
