Adjust the shift cables?
anthonysd
I am hearing a clicking noise as I try to put my alpha 1 into gear. Based on what i have read, I need to adjust my shifting cables. I am looking for some guidance in how to do so. Any help will be appreciated.
Thanks,
mkast
Re: Adjust the shift cables?
Are you moving the shifter slowly or using a quick motion?
ziggy
click here and then start reading at pp 2A-18. shift cable adj.
agree with mkast. a snappy shift from neu. to either fwd or rev. is necessary for the gears to mesh quick instead of sliding (ratcheting sound) into gear.
anthonysd
I will try it quicker, I have been going real slow. No problems first couple times out, but now seems different.
anthonysd
I agree that quicker is better, but still hearing a short session of ratcheting. I haven't had this before. Maybe the sign that I need some adjustment? If so, does anyone have a good clear procedure/diagram for doing so?
Ayuh,... The link Ziggy posted is the factory shop manual,...
Just how gooda instructions do ya need,..??
Shift cables don't just go out of adjustment...
It's more likely it's dying, needing Replacement...
