my new fishmaster
Thread starter- Joined
- Aug 11, 2001
- 256
I have the clymer manual which does not help at all. Mine is a 96 75hp force. I realize the idle screw needs to be lightly seated clockwise then 360degrees out. There is a warning on the engine saying anyadjustments will require linkage adj? I have never used a timing light or strobe. When I went to the lake I could only go 19mph at 3500rpm thats a 1000lb 17alum with the 230lb motor 600lb gear with a 17degree prop.
