Adenoids??
Paulz01
The guy that i bought my boat from said that the adenoids needed to be replaced. Can anyone help me out with this? I dont know what that is and dont know where to get it.
Haut Medoc
Re: Adenoids??
Anodes?.......:D
They are the sacrificial zincs on the drive......:)
Paulz01
Re: Adenoids??
Okay...I have a Volvo Penta 275 that needs them replaced. Can you help me out here? Where do I get them and how do I replace them? This is my first boat.
Haut Medoc
Re: Adenoids??
I'm not a Volvo guy so I can't help with specific info.....
They are the parts attached to the drive that are bare, grey metal....
It would be helpful if you could post the serial # which should be on a plate attached to the upper drive....
Don S will be helpful on this, I'd keep an eye open for his reply.....
Ya might want to start a thread with 'Volvo anodes or zincs" for a better reply......:)
Silvertip
Re: Adenoids??
Just don't ask for Adenoids when you go the parts house. Kids with chronic sore throats and ear infections usually end up having their "Tonsils" and "Adenoids" removed. The devices you are asking about are called "sacraficial anodes" (anodes being an electrical term). Look where the handle on the bucket is. Just to the right of the handle is a grey/white rectangular piece of metal. That's a sacraficial anode. In this case there is just one bolt holding it on. There are usually at least two of these an on outboard. Your VP may have more. Size varies as well. And don't ask what the bucket is for. The answer got someone upset the last time the question was asked!!!!!
Robj
Re: Adenoids??
Just go to your VP dealer and tell them the model and year of the drive and that you want to buy the sacrificial zinc anodes. I know there is one behind the prop and I believe there is another one also. The dealer will know and they are really easy to replace.
Don't just say you want to replace your Adenoids, they may think you are talking about something different and send you elsewhere.
Have a great day,
Rob.
QC
Re: Adenoids??
Believe it or not there is also an engine part called an aneroid, don't ask for that either :eek: :p :D
Scaaty
Re: Adenoids??
The anodes are a big ring right in front of the prop (ST, VP's don't have that zinc), and a bar about 6-8 inches long in front on the leg, way up by the transom mount.
The prop ring comes in two syles (one for Duo prop) , so get the right one. Not sure if a diff on the bar. If Iboats don't have them, West M or Boaters W has them in stock.
Be prepared to snap off a bolt. Easy to drill out and re-tap a size up though. Use SS bolts.
Alright... looked it up . Can't beat "Boat Zinc's" prices. Google it. Navigate around.
Volvo Penta 280 Zinc Anode Kit
Kit includes:
V-18 (875815-3) Volvo
Penta 250T-280 Outdrive
Ring Zinc Anode
832598 Volvo Penta 200-
280 Outdrive Bar Zinc
Scaaty
Re: Adenoids??
Thanks for the help guys
Thats what we do here...help each other! And the "bill" is in the mail now. (kidding with ya)
Go real easy pulling the bolts..little back forth, ON BOTH, 'till they seem loose. Best to use an "Allen" wrench..and a rubber mallet..easy rap, back and forth. Straight force, and cheater bar, will FOR SURE twist it in half. You want to break the corrosion. If one is coming out OK, put it back kinda tight, go to the other.
If it also comes out , your home free.
If not, and one twist off, just drill it out using that hole as a "jig". Only go far enough in to get a good 3/8ths inch into the mating metal. Then pull it off, and use the other bolt for depth guidance. Drill the same depth, plus a touch more (there is plenty of metal "meat" to work with on both)
Standard are 5/16ths NC SS Sockethead bolts. Go up to 3/8ths NC (use a 5/16ths drill). Then get a 3 Tap set of Taps. Use the starter tap, finish with the Plug tap (full threads on that tap). GO EASY! Few threads in, back it out and clean off the tap, and do the same 'till bottomed out.
You break off a tap in there, and your day will go downhill fast.
Go easy. Light touch, and a little Kerosene is a good lube for the Tap on Aluminum.
You will also have to drill out the Zincs to the proper size also. 3/8ths all the way..(Zinc only), and "spot" drill the Zinc with a 9'16ths drill, about 3/8ths-7/16ths in, for the Socket Head. SS Sockethead screws available at any good hardware store.
Good luck (Machinist 21 years, and my 280 sits in "salt"..know of where I speak here..had to do my prop ring a few years back, and the bar this year)
Any problem, post again...Oh yeah, those VP's are pretty well "bullet proof".....BUT... (get a manual NOW..do it right!), check for "milky oil", and replace both the drain screw gasket, and for sure the oil fill gasket..(kinda "chinsy" in my book...don't last long)..and a new ORing on the Dipstick.
Put 2 1/2 quarts straight 30wt in there, then top off at the dipstick hole the rest..holds 2.8 qts...and remember..(the manual thing)..there is a "pump" at the prop shaft inside, that supplies oil to the top end bearings.
Running in "neutral"...will NOT supply that top bearing...stick it in gear.
Again, good luck...hope all goes well here.
PS..might mean a lot if you told us the age of the boat/motor, motor size, last time the exhaust manifolds were changed, raw water cooled or fresh, Saltwater, or fresh..etc.
More involved that ya think... I/O's are high maintenance items.
Also if you pull it out for storage, take the Zinc's off..stick them in a coffee can of water and cover. They will oxidize in air, and become useless..
Paulz01
Re: Adenoids??
The boat is a 1987 Bayliner Capri 195 cuddy cabin and it is freshwater cooled. Thats about all i know about the boat right now other then it has been sitting for the past year.
I got the boat because it came with the trailer that i was buying. They guy decided that he didnt want the boat anymore so decided that he would sell them together. If it become to big of a deal, i will just sell it off or donate it. If anyone knows anything about this boat, your info would be much appreciated.
I will have the boat the 16th and hope to get it running asap. I will get you guys plenty of pics once I have it.
Scaaty
Re: Adenoids??
I have an 88 125hp OB Force...same boat, only OB...if it was well taken care of...well, ya might just like it! Keep us posted....stick with the same thread...let us know..
