Re: adding lights on pontoon,fuse gets hot
we got a 1989 lowe party boat and would like to add some extra lights on front ,so i mounted an old set of fog lights and conected one one them to fuse box just to check if it worked. the fuse got hot very quick. do i need to run a bigger gauge wire from battery to fuse block or bigger wire to lights themselves?
If the fuse got hot, I expect at some point, someone put the wrong fuse in.
You need to do more than run a bigger wire somewhere, you need to understand boat wiring or you run the risk of setting the boat on fire. All circuits need to be protected by appropriate sized fuses or circuit breakers. From your description, you already have an electrical issue on the boat or the fuse would have blown instead of getting hot.
My suggestion is to have the boat checked out, and the lights installed by a competent marine electrician. If for some reason you don't want to do that, the next best choice is to buy a bool on boat wiring and read it. If it makes sense to you, fix your boat yourself. If not - find someone qualified to do it.
