Adding additional trim switch Force 75hp 1997
icegator
I need help, with the wires I need to splice into, in order to add an extra trim switch. The only trim switch is at the outboard controls. I would like to add another switch closer to the outboard, so I can raise/lower it easier from the rear. Is there anyone that is familiar with this? I have a 1997 force 75hp w/trim.
RRitt
Re: Adding additional trim switch Force 75hp 1997
find the wires from console switch and wire another switch in parrallel with it. You're in trouble if someone pushes up on console at same time that you push down at transom. Barring that, it is perfectly okay to just splice the new switch right in with the old one.
