Adding a trim indicator to 888 Merc One O/D
Boomyal
Is this a possiblility? The trim limit and O/D lift work flawlessly.
Re: Adding a trim indicator to 888 Merc One O/D
Boomyal,............. You're a Master Boatman,............
Do you Really Need or even Want a Cute little Gauge on the dash that is Absolutely Useless,...??......
Your Righthand,+ the Seat of your Pants is Gauge Enough,..... Isn't It,..??....
Boomyal
Ah Bondo, the recognition of true talent is the beginning of wisdom.<:)
Ayuh,.......... I'm Wise,+ Your Talented,.......
But,........... You didn't answer My Questions...........
Trent
Its very possible and a waste of time and money. But if you want to do it you can. Gages are cheap but then you got to buy the trim sender. It only comes it the kit now. You get the trim limit and sender and the wires.
Good luck cause in a few years the gage will not be working. :'(
