Adding a temp gauge...
joshrogel
I need some help, as usual....
;I have a 72 85hp outboard Johnson. There are a couple of wire disconnected on the motor and was told they are used for a temp gauge....
My question is what type of temp gauge would work?
Thanks in advance...
rayodunne
Re: Adding a temp gauge...
I think the wires you speak of are from the temp sensor which operated auto half choke on the motor. There was a service bulletin to disconnect this and wire both wires from choke solenoid to the same terminal.
wilde1j
This gauge comes with a sensor, which mounts by threading into a tapped boss on a cylinder head or surface mounted with a 'Z' bracket and the whole deal is intended for outboards only. Should be < $50.
Teleflex Wtr Temp
Teleflex Premier - Pro Series
Fog-free design. Crisp modern look. Black dial with white & blue graphics that back-light red at night. When illuminated, advanced light piping distributes light across dial & into pointer staff for excellent night readability with no halo around dial.
Attributes/Specificatons:
Estimated Shipping Weight: .55 Lbs
Estimated Shipping Dimensions: 4.2X7.9X6 Inches
Manufacturer: Teleflex
Part Number: 62748P
