adding a starter to a 25hp Evinrude 1990
Thomas Smith
Having some problems. I Have a new starter a new battery, a new solinoid. finally got the flywheel and starter to match. 11 tooth starter 54 tooth flywheel. Will barely turn over.
Your ideas please.
TJ Smith
kbait
If thin gauge wire, may not carry enough amps to spin..
flyingscott
Bad ground or a bad connection will do the same thing. Dis you get good jumper cables or cheap?
