added weight
Teufel22
I recently purchased a 1987 Sea Ray 268 Sundancer and finally got around to cleaning out all the compartments. On the port side approximately center line there was a compartment in which I found what appear to be two 50 lb square dumbbells. This is definitely not stock, it is a sliding storage compartment and not somewhere Sea Ray would have stored ballast. My question is, is there a good reason for it being there or did the previous owner just like to work out while out fishing? I have only had the boat out twice and haven?t even got it on plane yet due to engine troubles. I wasn?t sure if this was a standard practice to correct a listing issue with these boats. I just don?t want to take them out only to find out underway that they are needed. I didn?t have my camera with me today, but I will post pictures tomorrow. Any help would be greatly appreciated. Thank you!
Fireman431
Re: added weight
No and possibly.
I'm sure it was added ballast, possible for heavy coolers, extra battery(s), or whatever. Remove it and start working out with it instead.
jigngrub
Re: added weight
If the weight was on port side, I'd say the previous owner was on the "portly" (pun intended) side and was needing a counterweight.:p
roscoe
Re: added weight
50# weights are easier to work with than concrete shoes.
For one, you don't have to wait for the concrete to set up.
2 - less mess
partskenn
Re: added weight
My 268 will list to starboard unless you have the water tank full. Full tank she sits level.
