swimmin' for shore
Thread starter- Joined
- Oct 25, 2004
- 490
I'm not a mechanic. I'm getting better, though. I'm getting a conflicting understanding of the term "low compression". I understand how to check it, and very basically what causes it...What does it do to you, though? Does your motor run more weakly? Some say that it doesn't matter, as long as each cylinder is within 10% of the other. Is this true? I feel like 50 psi on cylinders that were set up for 125 or so is bad, but is it? Do I avoid all motors with low compression? What are the most common causes? If there's another place that I should be reading, please redirect me. Thanks.
