Re: acetone
I have used it a couple of times....seems to work well.I had used laquer thinner once.Is that any better or worse.I am changing my thru hulls right now and I thought I had read somewhere to clean and prep the area around the thru hull hole prior to putting in the new one with the bedding compound , you used acetone.I also heard it was ok for the odd stain....just wanted to make sure.<br /><br /> 2600
