JustMrWill
Master Chief Petty Officer
Thread starter- Joined
- Aug 12, 2003
- 877
I have been reading for about 2 days now...and I understand that a simple "use #14 wire for accessory X" is not the correct answer. I have printed out all kinds of charts saying that the wire gauge should be X if the run is Y and the amp draw is Z but, what I can't seem to locate is the average/max amps used for accessories that I already have on my boat. I understand that simular but differnt items will have different needs (a double air horn vs a single air horn...led vs reg bulbs). Is there a chart/link that shows Nav light = 1 amp, horn = 5 amp, etc? I have been searching various manufacture's sites to try to get the specs but most dont say anything about amps or watts...just that it is a 12 volt item.
Am I worrying too much? Should I just copy the wire size that the accessory came with (the 4" tails) and figure "close enough"?
Here is what I have (all existing with no markings on them):
Nav light (single bulb).
Single horn (looks like.. http://www.iboats.com/AFI_Mini_Comp...68938908--list_time.1181322117--view_id.37987 )
Anchor light (on pole)
Bilge pump (Rule 450 gph)
Humminbird WIDE Onehundred depth/fish finder.
If anybody can tell me the amps I can figure out the wire I need to buy.
Thanks.
-JMW
Thanks.
-JMW
