Accessories not working
NeilE.
I’ve had our boat, 2021Nauticstar 249 XTS, covered in the backyard for the past 3 months while recovering from knee replacement surgery. Pulled the cover yesterday in hopes of getting her out today when I noticed that I had no accessory power. Trim motor works, trim tabs work, Simrad turns on, command center comes on but no radio, lights, horn, pumps etc. Put the batteries on a charger overnight, no help. Bought a new charger this morning and although it shows the battery charged after several hours I have nothing. The command link shows both batteries near the bottom of the meter. Any suggestions? Is there a fuse I should be looking for? Is it possible that the house battery is just dead? Less than 30hrs on the boat.Thanks.
NeilE.
I do but would rather fix it and get back on the water if it is something simple instead of waiting for the dealer to get to it.
I thought that is what this forum is for.
call the dealer, ask where the accessory power comes from.
dingbat
It’s quite possible you have a dead battery especially if you left the battery switch on the entire time.
I would start by measuring the voltage on both batteries.
briangcc
I'd take both batteries to be load tested. My gut is telling me that you have just enough juice to operate a few low draw accessories but not enough to turn the boat over or other higher draw accessories.
An onboard head unit (radio) with memory will draw a battery down over the length of time it sat unused....which is why I turn my house battery off when not in use.
