tim thompson
Thread starter- Joined
- Jul 6, 2010
- 53
I removed the bolt to latch in order to remove stat cover but bolt is too long so I can't get the latch and bolt out of the way. So I am asking for suggestions. I replaced water impeller with kit and decided to flush upper by hooking hose to copper intake. A little dribble out of pee hole . So I want to inspect upper grommet so need access. What gaskets or kits will I need if I have to take off power head. What else to look for ... replace thermostat ?? etc.. Boat is fresh water but been sitting for 15 yrs or so. If I have success on this motor I have to repeat on the 35hp. Same problems. Thanks
