Re: acceleration issue on merc i/o 230
Basically there are 3 things that can cause this, 3 points where the power transfers between engine and water (other then the gears and stuff inside the drive, but when that stuff goes you go no where and may hear big noises)...
1. Prop slippage due to cavatation. Your prop sounds like a candidate for this. The little chunks could be causing air to be introduced into the prop stream or too high of a pitch and it will loose it's "traction" or bite on the water.
2. Prop hub bad and spinning under higher load. Mark you prop across the center to the outside of the hub and try it again. If it's misaligned there is your problem.
3. Engine coupler. This is similar to the prop hub but is bolted to you engine and all power transfers thru this. Usually when it goes you will not get much beyond idle and you may smell burning rubber or see smoke from the engine compartment. This is a $300 part and requires engine and drive removal.
You situation sounds much like #1 or maybe #2. Solution to either is to replace the prop.
