Re: ac plywood
Yeah, I suspect GB is correct. It was probably 1 1/2 " so two pieces of AC FIR Exterior Plywood Glued together with TITEBOND II wood Glue would do the trick. I'd recommend sealing the edges with 10 minute epoxy and then Painting with two coats of Rustoleum's Professional Oil Based Paint. Would Last a LONG time. If you want it to last for a VERY long time you could buy a gallon of polyester resin from Lowes along with a couple of yards of Chopped strand Mat and coat the wood with that and it would last for decades.
