mikemerrill50
- Dec 3, 2005
- 84
ok, so there is pretty much no way of me putting a fuel tank below the deck of my boat due to how shallow the bilge is (it doesn't appear there was ever one underneath). so, I am looking at my options for mounting a fuel tank above the deck.
here are the options i have considered, with each option coming to around 40-50 gallons:
1. two above deck tanks, one on each side under a seat
2. two above deck tanks, wedge style, one on each side under the gunwale
3. one above deck tank, mounted under the rear seats (forward of the motor)
4. one above deck mounted in the center of the boat...?
5. several smaller tanks...?
I have a question:
With having multiple tanks, I have been told before in the past, on here and other places, that you should not connect them. I have also been told it's against CG regs. Is there reasoning for this? Do you recommend against it anyways? If I do have multiple tanks, should I get a fuel switch to switch between tanks? If I go with two tanks, I wouldn't want to run on one until it runs low, then have the boat completely off-balance.
I have a few worries about those options.
1. One of course is weight distribution. This is actually one of my main worries about this project. What do I need to take into consideration with weight distribution? Is it ok to mount a tank near the stern, or is it too much weight when combined with a motor?
2. On similar lines, I'm worried about stability. I like to ride in rough waters, and I will be using this boat for some slightly offshore (just to 3nm) trips as well as intercoastal waterway. Would having the wedge styles in the gunwhales make the boat too top heavy? Would putting any tank above deck make it too top heavy?
3. Noise. I don't want to hear the fuel sloshing around the whole time. Of course, I know I can eliminate at least some of this with insulation or soundproofing.
Do you have any other ideas for ways to do this?
Thank you always,
Mike
pictures:
http://rides.webshots.com/album/530653041gHTxRa
I have a question:
Thank you always,
Mike
pictures:
