191Seanymphstriper
- Aug 23, 2010
- 265
My younger brother has a 18 starcraft CC that I had never had a chance to see before yesterday. He lives in N.J. He is not like me as far as rebuilding and restoring aluminum boats. But he does love the aluminum boats.
He is the type to just do things quick and just go fishing etc. Well he has had some motor trouble and he brought the boat over to pops house yesterday and when we got home from fishing on my boat we took a look at her.
Well first off his zinc was eatin to the core. half hanging on. Almost totally gone. I crabed the zinc and it fell off the bolt into my hand. So he ran and got new zincs as I changed his plugs and coils and cleaned the carbs and she fired right up. So that parts fixed.
My brother then got back with the zincs and We were installing them and I got a close view under the hull etc... I fount that on the outer side spray chimes and the under hull keel chims there where lots of pitting, Along the stained water line especially in the outer transom there was alot of pitting as well where the water sits when the boat is docked.
He had painted the bottom of the boat with trilux 33 but he diddnt come up high enough with his water line with the bottom paint. He also just sanded it and applied the trilux 33...
Now when i paint the bottom they sell a primer that you use to apply before you add the trilux 33 and I do things a bit diff so I dont have this issue.
Also I have a dual battery charger by guess that after reaches full charge becomes a maintance trickle charger and shuts on and off to maintain full voltage of the battery. I also have a switch to turn off the dual batterys when im charging and not using the boat. I also keep my boat in salt water and charge it etc
Now my brother has a single battery and a single guess battery charger as I do but with no switch.
But he my brother just does things kinda half A%% .... So my question is this.
1. What are your thoughts as to what caused the electrolysis to start eating at his boat?
2.Is it the fact that he never pulled his boat out every month and checked his zinc and the boat started to get attacted by electrolysis?
3.Or is it the fact that he did not apply bottom paint to where the water line was supposed to be?
4.Or is it the fact that he did not prime before adding the trilux 33 and the bottom paint is causing the electrolsis to eat away?
5.Or is it the fact that his charger is charging a battery that is directly connected to the boat with no switch to cut direct current to the boat while charging?
What can he do to further prevent this from happening again?
I told him that Over the winter I will aluminum soder weld these little spots and sand them down to a like new finish for him but he dosent want me to
"Go all out he said" My brother is hard headed and I think he likes to do things himself! Like I said hes not as anal as I am about theses boats either.
6. So also what is a easy quick fix that he can do to fill in these little craters himself where the electrolysis ate the aluminum? G.B Weld? Is there a aluminum type bondo?
He brought the boat home last night and wants to put it back in the water asap But im trying to get him to do some type of a repiar before he puts her back in...........
Any input, advise, thoughts, etc would be greatly appreciated! So thanks in advance for any input.
