jeff_smith_0423
Thread starter- Joined
- Dec 5, 2007
- 492
Evening...
So, a few have followed my "back to life" saga with my Merc850. Tonight I hauled the rig out of the garage and fired it up again. My goal - achieve operating temperature and allow to idle for a period of time. I wanted to get about 20 minutes of consistent run time. Why so long? The closest body of water is 35 minutes away, is known as an "unfriendly" lake, and i would really like to get a little bit of confidence with the motor before I put the boat in the water.
So, it's about 40 degrees out here tonight. Haul out the rig, hook up the flush muffs, and it's alive and idling after three cranking cycles and a healthy dose of choke - i expect these motors to be cold blooded and that isn't alarming.
I allowed it to run for a bit, shut it down, restarted with a half second of cranking. Allowed to run at idle for about another 15 minutes with no issues, and then it just stopped cold. Not froze up, no sputtering, just stopped.
When i went to restart, i checked the primer and it was still solid. With a LOT of cranking and choke, i was able to get it restarted, but had to give it a lot more throttle to keep running. I would say that the throttle and timing arms were moved at least 3/4 of an inch off of their stops. Throttling down causes it to stall instantly.
So. Is it possible that it actually took 20 minutes to come up to operating temp and my idle setting is just that far off? My idle mixture screws are set at about 2 and a quarter turns out. Was hoping to do the final adjust once it was in water.
I have NOT done the sync & link procedure, as I have no way to mount the motor in a test tank, and i don't have a body of water i can get out on to do it underway. However, the P/O appeared to have been a relatively conscientious maintainer, and i don't have any real reason to think they're terribly off. Especially after how well it seemed to run when cold.
Ok.. that was long. And rambling.. and might not make any sense. I don't have any idea what could be causing this problem. It got dark and I had to put it away so i couldn't restart after it cooled to see if the problem only happens when warm.
