My son just bought a 69 StarCraft Trident.
I am trying to do some research for him, but am not finding much.
It has a MerCruiser 120HP I/O
The prop is pretty dinged-up. I assume that there are ID numbers on the old one, but I have no way of knowing if it was original. Anyone with a similar boat want to let me know what they are running?
The original fuel pump is not working. PO suggested installing an electric fuel pump, (cheap and easy).
Is there any reason NOT to do this?
I have worked on several old fiberglass and wood boats in the past, but am not familiar with StarCraft. I was surprised to find a bilge plug in the bulkhead, between the bilge and the engine compartment. When we pulled it, we found that there was A LOT of water trapped in the bilge. If I were to do some "exploratory" and look under the floor, what can I expect to find in the way of construction?
The engine area has no stringers visible. I would assume that there are two stringers under the floor. Is that correct?
I'm sure that there will be more questions as we get into this.
Thanks in advance,
Mike
Thanks in advance,
Mike
