!992 3 cyl 60 HP Flywheel retainer torque
Davee3
The abbreviated manual I am working with does not seem to ID torque & installation
1) use threadlocker or ? 2) torque required ?
Finishing a rebore oversize caused by overheating (common problem with these i am told) I had a n additional water bleed drilled & tapped to avoid air bubble problem New water pump parts B$ restarting
Appreciate some help Thx
Honorary Supreme Mariner
Re: !992 3 cyl 60 HP Flywheel retainer torque
Assemble with tapers clean and dry.-----------No thread locker required.--------Torque to 100 FT-LBS
boobie
The actual spec out of the book is 100-105 FT-LBS. !!!!
