FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Is the primer bulb the only check valve in the fuel line for my 99 mercury 2 stroke outboard. If the bulb check valve is iffy, could the engine faulter at WOT? Thanks, Cliff
Thanks for the feed back. I may have found the faulter/stumble issue. My line and bulb are only 2-3 years old, but the bulb is acting like the check valves in it are giving up. I was still using the OMC quick connect from my previous outboard at the tank. I think the seal in it was letting air into the fuel line along with the cheap pinch clamps on the bulb. This may have been letting the engine run out of gas at WOT. I replaced the disconnect with a hose barb and the pinch clamps with hose clamps. I also replaced the square o-ring on the filter/ screen cup that may have been leaking also. I will have to run it on the lake to know as it only shows up after a minute or so wide open. I'll let you know.
