bullgator99
- Aug 30, 2004
- 43
My 99 Four Winns has been taking on water this season. I've isolated the leak to the aerator pump and the inlet hose attached to it. I tightened the hose clamp really tight and it seems like the leak stopped. At any given time there were a few inches of water in the bilge. Barely enough to wash back into the bottom of the ski locker. But when I removed the deck to access the area I noticed the plywood separating the fuel tank from the bilge/battery compartment was damp. It's wet but it doesn't seem to be rotting.
Layout with deck removed.
The leaking connector.
The pump itself.
Hose connection to through hull fitting. This spot is REALLY hard to get to. I might have to remove the plywood that the batteries sit on. It is held down by two rusty lag screws and might also be bonded to the underlying fiberglass. I'd rather not fool with it.
Damp plywood.
Questions: Should I go ahead and replace the hose and aerator pump? I'm worried that it might start leaking again. The boat stays on the water and I don't have an automatic bilge pump. But that hose would be a bear to replace -- it's very hard to access where it connects to the through hull fitting. I also question whether anything needs to be done about the damp plywood down there. Opinions?
The pump itself.
Damp plywood.
