'99 Evinrude outboard 225hp not going into gear
nwresticnet
I need some help. My Evinrude outboard 225 is not going into gear. I had a person look at it. Said it was not the cables(not stiff), not in the lower unit( went in manually easily).<br /><br />He said I need to replace the control box. Is this correct for a 1999 225hp? The boat & motor have been cared for and not abused. 209 hours.<br />I have a frien who has a similar motor that is a '94 model and he has never had a problem with his control box.<br /><br />Bob
rickdb1boat
Re: '99 Evinrude outboard 225hp not going into gear
If it goes in manually, the lower unit is ruled out. I believe the cable may be broke inside the sheath. Remove the cable end from the motor and give a good pull on it. If it comes out, you know the answer. If not, something may have worked it's way loose in the control box, but it would certainly not mean you need a new one, Just a repair you could probably do yourself. The cable end in the control box could have come off, too, do to a loose retainer. Check the cable first. Most likely problem! Just because the cable is not stiff, does not mean it's not broke. In fact, a broken cable would make it easier to move the control lever. Been there, done that.
nwresticnet
Rick, thanks for the reply. Now that I think about it a little more, seems the first problem I had was that when shiftiing to reverse there would be a little "clicking" before it would go into gear. One month later, it did not go into reverse at all, but would go into forward. Now when trying to get it into reverse, the throttle can be very difficult to move backwards (almost stuck). I would not force it. Then later, it would go backwards without any trouble.<br /><br />Bob
rickdb1boat
Cable is broke!! No biggy to replace! Try to get the "Red Jacket" cables, as they last forever. Replace the throttle cable while you're in there, too. Good practice! The reason for the clicking is that the cable strands were breaking inside the jacket and catching on the inside of the jacket when you shifted. Forward, it just pushes the cable, broke or not.<br /><br /> Red Jacket Cables <br /><br />They are not cheap, :eek: but you will definitly notice a smoother operation and will not have to worry about them ever breaking.<br /><br />Or regular cables:<br /><br /> web page
rodbolt
hello<br /> If you have the OMC control box then open it up and look for sheared nylon teeth. dont use universal cables. only use the snap in cables. had a lot of problems with those boxes. the teeth would break off if forced due to a bad cable or the warm up levers come loose. in the case of the binnicle mounts the pot metal arm will bend or just snap off. I do a few of these every year. carefully test or best,just replace the cables clean ,inspect and lubricate the control head. and double check the bushing at the power head for the horizontal shift shaft. it has a grease fitting that never gets greased. the late 90's were a bad time for OMC. <br /> good luck and keep posting
nwresticnet
Rick & Rodbolt, thanks for the replies. I will let you know the outcome!<br /><br />Best Regards,<br />Bob<br />Corpus Christi, Texas
DMR Mechanic
If you have a Binnacle Mount control, it could be the end has broken off the Shift Lever. I have had this problem on many of our boats.<br />Part # 126471
nwresticnet
Rick & Others, turns out that the control box DID need to be replaced. When they took it out, the main metal bracket in which the entire piece is made around was rusted completely thru the middle from top to bottom and had broken in half!!! Therefore, my problems. I was told that the metal is a cheap type of metal and should not have been used. The part was made in Mexico.<br /><br />The new part was made in Mexico too, with the same cheap metal...<br /><br />Not too happy.<br /><br />Bob
