'99 90hp Ficht running for winterizing
REVTECHss
Boat is out of the water already, can I hook my hose to the water exit port (water pump indicator) and run it for fuel stabilizer circulation, and fogging?
DHPMARINE
Re: '99 90hp Ficht running for winterizing
Not sure on the Ficht,as to the exit port fitting.On some motors that is for flushing when NOT running.But you can certainly put a flushette on the lower unit intake and do it that way.Just keep that 90hp at an idle when on the hose.
DHP
REVTECHss
I know its for flushing, but I have a newer Ficht manual and it says you can use the port for flushing while running. Just want to know if its ok with my motor too, or do I have to get the muffs to run it.
Hoping to get this done tonight so if anyone knows I'd appreciate there help.
