Re: 99 3.0l questions ... Proud owner of 99 Sea Ray 180 /pic attached
Wrx - if you can run at 4900 rpm, you're under-propped. Sound like you need to go up a couple of degrees on your prop pitch or find a larger diameter prop.<br /><br />Also, rather than relying on higher octane gas (octane degrades as fuel sits in the tank, so relying on 92 RON is NOT the best way to prevent dieseling, as a long-term solution), it's a much better idea to check and adjust your timing - it sounds like you may have a serious timing issue that, left unattended, will do a great deal of harm to your motor. Make sure you follow the service manual procedure for checking and adjusting your timing - it's not like checking the timing on an auto engine - or have a qualified marine shop do it for you. Also, check the carburetor adjustment (mixture, idle speed, etc.) to make sure you're maximized there, too.<br /><br />These little 3.0 liter motors are pretty reliable if you just pay attention to maintenance. There are a lot of guys on this and other boating forums who opine that larger motors (V8s) are the best way to go, but, with gas costing what it does now, I think those of us with 3.0s and 4.3s are in the catbird seat. I usually anchor my V8-powered Bayliner in the middle of the lake to use as a party barge and my friends and I run around in our 3.0-powered bowriders for fishing, skiing and wind-in-the-hair fun!
