!988 85 hp force will not throtle up above 2000 rpm
chuck01
Hello,
This all started when the motor cover or hood insulation came lose and some was sucked into the intake. Carbs have been blown out with low air pressue. It will crank fine and runs fine at 2000 rpm. If you try to throtle up it will cut off, unless you push the electric choke in and then you can give it the gas and it runs great. Anyone have any suggestions other than a shotgun.
Thanks,
Chuck
rosco_59
Re: !988 85 hp force will not throtle up above 2000 rpm
Take the carbs apart and clean the good. Sounds like they are not getting gas. Just my guess, hope it helps
roscoe
When you have the carbs off, look into the intake and inspect for debris in the reeds. Don't bend or damage them.
ewbish
chuck01 said:
Hello,
Thanks,
Chuck
That right there is a near text book discription of a plugged main jet. Take your carbs apart again, and remove the main jets and check for blockage, make sure the passage way isn't blocked as well. Your float needle valve could be blocked as well, but my money is on the main jets and/or the passageways. Don't rely on blowing through with compressed air, use a can of deep creep, wd 40, or carb cleaner and spray into the passageways to make sure it's flowing through.
kenmyfam
Great advice given above, I agree with them totally.
