!985 150 merc carb question
CU2NITE
When I sqeeze my fuel bulb I noticed one of my carb jets is spurting fuel. What would cause this? And would this cause my motor to bog or miss at low rpms? It runs great at high rpms.
Thank you
CU
RUNNING THE MOTOR WHILE LISTENING TO THE HORN WILL MAKE YOU MORN!!
Laddies
Banned
Re: !985 150 merc carb question
In some cases the bulb has enough pressure to force fuel by the inlet needle if the engine idles without alot of smoking it will probably be alright for a while if if smokes the inlet needle is leaking
CU2NITE
Will this cause a runnability problem?CU
CU
Laddies
Banned
Not if it's not dripping at idle, if it don't drip at idle then the excessive bulb pressure pushed the needle off the seat
CU
you may have a low speed jet stopped up,clean carbs blow all stationnary jets real good
