Hello all, I am new to this forum and in hopes to acquire some knowledge about this very old 1968 9.5 outboard motor of mine.
1968 9822E Evinrude Very clean but not good running condition
Problem:
Top cylinder is miss firing or back firing at low idle causing very rough idle (when unplugging top cylinder engine runs smooth)
Engine guzzles fuel and not much power to show from it
Engine not reaching full top speed and feels as if only 70% of throttle being used, after 70% ++ throttle usage engine bogs down and wants to die (under load)
Past fixes:
New: Fuel pump, Coil + Wires + Spark plugs all in 2013
In 2013 the motor was sent to the repair shop ($250) to fix the timing and carburetor (that i have messed up), The shop told me the Reeve valve for top cylinder is what's causing rough idle and not worth the tear down to fix it.
I have good knowledge of most basic and older car engines such as how they function and mechanically work, but i am not familiar with boat engines and especially this old one. My lack of knowledge is the throttle and timing settings for it.
I know the points settings, and such but it seems like i have messed something up regarding the throttle position. IS there a notch that the engine throttle suppose to be when at idle and when at max revs? i am not sure how the Advancing throttle works / positing.
I will pick up an compression tester soon and help to troubleshoot a rough idle reeve value issue.
Problem:
Past fixes:
