old boat 54
- Oct 12, 2008
- 79
I have a 98 xl 1200. #1 cylinder went out. Mechanic did top end tear down and said oil was good to bearings, and does not look like it went lean, but mechanical failure on piston ring.
Head would be bored ( all three cylinders) with new rings, gaskets. remove crank, clean up and check lower unit for small metal shavings from piston. Piston in one piece but beat up.
Looking at $1800.00 to fix, but said crank could be worn. Will not stand behind crank. Crank is another 800.00. The 1800.00 alone is reaching the value of boat, I think. Boat is good shape but normal wear and small dings. approx 260 hours. I am 2nd owner. took care of and winterized properly.
Looking for opinion: Is this worth fixing, or put money towards ne 4-stroke. do not want to put the crank money in it. Not sure if it really needs it.
Any rebuild guys out there, need your help. I could do the work, but would take me a while, as busy with work. Then labor cost wont be issue.
Thanks for any help. I need to make decision fast.
