My 9.9 won't stay running at idle for more than a few seconds. If I push the key in (primer) it will come back slightly before it dies. To re- start I have to push the key (prime) in and advance the throttle. It seems run fine above idle now, though a couple of weeks ago it was losing top end - but that issue went away. I also notice my tach will at times will bounce +/- 50 RPMS and others its's rock steady.
The pontoon has an onboard fuel tank, but I borrowed a portable with known good gas and it did the same thing. I checked the fuel filter on the pump and it was clean. Could this be as simple as the fuel pump or do I have an electrical problem?
thanks
thanks
