98 johnson 50 randomly stops pumping water
moe syzlak
1998 johnson 50 outboard. Had for 7 years with no issues but admit I havent replaced impeller. Drove boat to lift from landing no issues but water was weak coming out of tube. Week later went to use boat and no water comes out.. just a bit of exhaust puffs out of water tube. Replaced water pump and about 3 seconds after startup water started pumping better than ever. About 20 seconds later water stops pumping completely. .. not even a trickle. .. and small puffs of exhaust come from tube. Im lost. What could be causing zero water to pump? Thanks
mfkadz
Your going to need to get at the water pump again. Verify it was installed to spin the right way. Also verify the key is good.
You can run water up the water tube to see if there is a blockage up top. I have not heard of many blockages.
mike
moe syzlak
Thanks. New key with water pump kit. The impeller can only be installed one way on this engine and it wont go on if the key is not installed correctly. Whats weird is it pumped great and then quit like a light switch...
mfkadz
My guess is there was pressure on the shaft and then once it got lined up that pressure went away.
mike
moe syzlak
Can you explain what you mean mike? You believe the impeller is turning relative to the shaft and somehow slipping past the key?
moe syzlak
Ok. Pulled apart. Shredded key to nothing. Where does the 1 inch round oring go that comes with the kit?
moe syzlak
Fixed. Aftermarket impeller didnt have groove on bottom for oring like oem did. Installing the oring with aftermarket impeller that didnt have groove raised impeller too high causing too much friction on shaft to turn and shredded key. Installed old key with new impeller and no oring. Runs like a champ. Will probably replace with oem at end of season. Not sure why they provided an oring in kit if impeller didnt have groove for it to fit.
mfkadz
To funny, I thought you forgot the key the way you responded. I was saying why I thought it worked for a bit. But you did find that it trashed the key. Was that the new key? I take it you reinstalled the original? Not problem. Just wondering.
Hopefully that ring goes at the top of the drive shaft. That's where mine is. ;-). There's a groove for it just under the splines.
mike
