98 evinrude outboard 70hp headache
Boerboelking
HI first time poster long time reader. Bought a new 70hp evinrude 98 motor. Took her out for the first time 2 weeks ago. Ran poorly had sat for a while. Wot would start then die down to about 10 mph. Put it in troll and kick it back up she would start for a few seconds then the same.
Took her out... attributed it to dirty carbs or a fuel delivery issue.
Since then:
- replaced fuel tank and primer line (primer bulb) too.
- rebuilt all three carbs and replaced the floats
- put in a new fuel filter and fuel/oil pump
- new prop
- new gear oil and fresh oil in the tank.
Took her out this am...
Does not stall out anymore and moves faster than she did. But still lack power... it runs about a quarter of what she should. It will take off on wot may go for 10 or 15 seconds then slow right down. Holds slow speeds fine it seems.
Any ideas? Very frustrating. I've dropped abut 1500 without a solution. Thanks for any help.
Bosunsmate
Might be an electronic component failing. Have you checked spark?
Hows your sparkplug colours look? Any oiled up or a different colour to the rest?
gm280
When it starts to die off, try squeezing the primer bulb to see if that brings it back up. If so, you have a fuel pump fuel delivery problem. If not make sure the tank vent is totally open and not partially opened. Also check the compression in each cylinder and post back here with you results...
Boerboelking
OK will do... I tried squeezing the bulb last time I was out and didn't change anything... however before it would speed up die off slowly... this time it surges for a few seconds backs off... surges again.. back and forth ect. ..
Boerboelking
Am I missing some fuel delivery part? It screams fuel delivery to me... because if I back off for 5 or 10 seconds... then accelerate it seems to go longer... until it dies down... could this be electrical? After replacing the fuel pump it surges on full power... then slows then surges then slows... I noticed a small crack in the wire boot on cylinder 2... that's all visually I see that might be wrong.
Boerboelking
One more thing seems to work much better the less load... against the tide is worse than with the tide..out of the water I can't tell there's a problem with the muffs on. Why it was so disappointing today
Bosunsmate
A motor running on just one cylinder will seem ok on muffs. You could do a drop test on each cylinder
Bosunsmate
maybe it is a fuel issue, read post three
Boerboelking
Run it at night, check its not arcing. Run it wil the hood off, check its not shorting on the hood latch
OK sounds good will try tonight thanKS for your help. I will also find a compression tester and check to see how much drop I get between cylinders. Thanks again.
Boerboelking
After further research most likely cause now is the power pak 285 bux ... thoughts? Symptoms seem to include killing 2 cylinders under load...
boobie
Go to cdi electronics.com for ignition trouble shooting. It may not be the pack.
Boerboelking
HI just took apart the spark plugs again... gap was set very high... +.07 service manual calls for .04... didn't have a spark plug tool but looked up the thickness of a dime. Just over 1mm so used that as a reference to get it closer. Fire her up and she didn't stall at wot. Is this a lucky coincidence or would excess spark plug gap cause the issues I described? Thanks
Bosunsmate
Could do, i dont like coincidences.
Id replace those plugs, maybe the electrodes have gotten weak, next thing they may end up on your piston skirts
Honorary Supreme Mariner
The results of a compression test must be posted.-------The results of a spark intensity check most be posted.---Does spark jump a gap of 7/16" , yes or no.-----Is the motor overheating and going into S.L.O.W. overheat protection mode ?-----Has waterpump been inspected.?
