'98 Evinrude 200 trim/tilt blows fuses.
Dahlgren-Jim
My 200hp Evinrude (E200FCXEEN) just started blowing the lower 10A blade fuse, located in the relay and junction box, when the trim/tilt button on the motor cowl or throttle control is depressed, either up or down. Tilt motor works fine when hot-wired. Conditition persists when all relays are removed and the power leads to the tilt motor are disconnected. Help.
SparkieBoat
you have a short in the wire somewhere..follow that power wire to the place where it ties into your tilt and trim. it could also be in the harness running up to your throttle control tilt and trim switch or in the harness going to your engine tilt and trim switch, or in one of the switches themselves. try disconnecting wires and switches until you find the short, you can use an OHM meter to the engine ground to discern when the short condition is solved to save on fuses.
boobie
You could also have a problem in the PDP . ( power distribution panel ). Been known to happen.
doug kiser
Having trouble with tilt trim, does not go up or down. Motor runs fine. Where do I start troubleshooting?
boobie
It's not nice to hi-jack a post. Read the rules at to top of the forum and start a new one.
