98 baliner capri 1750 ls
mike ob
I just replace my battery a week ago, third one in 1 1/2 yrs always was real slow starting slow cranking. then today was out for a few hours wouldnt start . the positive wires were so hot that the post melted on the battery! not sure what the problem is. could there be a short with the starter? b/c each time I bruoght the battery back they tested it and was told it tested bad. any help????
NYBo
Re: 98 baliner capri 1750 ls
Welcome to iboats!:cool:
A bad connection at the battery post can cause a lot of heat, but given your history of dead batteries, I would pull the starter and have it tested.
spoilsofwar
Heat is usually a sign of resistance... Which is a symptom of bad connections, bad (corroded) wiring, or wiring of a gauge too small to support the load, etc.
Ayuh,.... Welcome Aboard,.....When dealin' with Electricity,... Heat = Resistance....
Yer battery cable, or it's end is corroded, or just plain ole Junk...
Today, 08:48 PM #3
spoilsofwar
Today, 08:48 PM #4
Bond-o
I guess the Great minds of Jeff Co. think alike, 'n bout the same time,.... ;) :D
