scumfrogmillionaire
Thread starter- Joined
- May 3, 2018
- 32
So I decided to do some preventative maintenance on my 20 hp Merc. The motor started and ran fine days before this. I noticed a bunch of corrosion on the spark plug cables, so I decided to pull them and clean them. While doing so I may have gotten a little water inside one of the coil packs when plugging the cables back in (not sure if this is the problem). Upon doing so, no spark whatsoever and the motor won’t start. I had 1 brand new coil pack laying around, and ordered brand new plug cables. Replaced 1 of the 2 packs and both spark plug cables and still no spark. How would I go about diagnosing this? I’m not going to just go out and buy another coil pack without knowing the problem. All wire connections and grounds were not touched. I simply cleaned the cables with water/vinegar, and re-plugged in.
