97 Johnson takes forever to cold start.
xzonex
I have a 97 Johnson 200 ocean runner, when trying to start first time takes 10 to 15 mins, after it finally starts its good to go all day, no more problems. Next time I want to go out it does the same thing. Can
anyone please help me with this.
PS. I had a brand new electrical box installed ($500.00) also the power head was replaced, we all know how much that costs, but even though when I took out the boat the problem is still there.
ondarvr
It's best to start with your current method of trying to get it started the first time of the day. Describe your method in detail.
xzonex
I put the motor straight up and down, pump the primer till hard, put the lever in neutral turn key to the start position without making it turn over, I then push key in for count of ten then turn key to start. It just keeps turning over without starting for quite awhile. Is there a certain position the lever should be in? I have tried all different positions, even the reverse in neutral.
ondarvr
Make sure the primer is working, you should hear a click when you push the key in. Also while holding the key in you can squeeze the bulb, this will force a little extra fuel in before turning the key to start it
xzonex
I don't hear anything click when I push the key in.
And if I try the starting fluid do I spay in all six carbs?
ondarvr
Your primer solenoid needs to work for the motor to start easily when cold, so pull the cowl off and see if you can hear it. If it doesn't work you need to figure out why.
The primer solenoid has a red lever.----The primer solenoid unlt only works properly when the motor is cranking over.----Pushing the key in for 10 seconds before cranking is NOT the correct way to use the primer !!!
ondarvr
Not really, it does allow some fuel to enter the intake prior to the motor turning over, this can let the motor start slightly sooner. I know very well that it is not a pumping mechanism, but if you have pumped the ball up you have pressurized the system just like the fuel pump does. This pressure forces fuel through the solenoid when you push the key in whether the motor is cranking or not. If you push the key in and squeeze the bulb at the same time it works just like the fuel pump.
The absolute worst thing that happens if you push the key in before cranking is....well....nothing....so there's no down side even if it doesn't help. But after several decades I can assure you that on some motors it makes a very clear difference in how quickly they start.
The solenoid valve will have pressure supplied by the fuel pump.-----Then it will spray fuel into the engine for near instant starts !!!!!!!
ondarvr
Of course it does, it will also supply fuel slightly sooner if you push the key in before cranking. Now explain why it won't work, or why it's a bad idea.
what does the compression look like
here is how I would start it
open vent on tank if portable
pump ball until its hard
I would also dissengage the gear (either pulling the handle out, or pressing the button at base), move throttle to about 1/4" forward.
crank and push in key.
when she fires, pull back on the throttle
if your not hearing a click when you push the key in, your enrichment solenoid needs attention.
also, never use starting fluid / ether on a 2-cycle motor. you can spray in pre-mixed fuel (I use an old 409 bottle currently)
xzonex
Thanks to all that gave me your help,I will let you know what I find out.
oldboat1
That choke presumably has a manual override. Use it to choke and start the engine, disengage it when the engine will continue to run (might have a half-choke setting for warm up period). Would give you a sense of how choking figures into your starting procedure.
Also the motor may have a " quick start " function that is not working / has not been checked !
xzonex
I found a red little lever what it is attached to has like a air fill valve, is this the right thing? I also heard that click. Now that red lever should I move it a bit?
